46-350 works too well
I've just finished getting the 46-350 working well (had to replace the output transformer), and the problem I have is that it;s working TOO well. I can't get the volume all the way down. It seems to settle somewhere in the mid-range, and I can't completely silence a station. I checked the volume control for shorts and proper values and everything seems in spec. I replaced a couple of out of spec resistors along the way as well with no difference.
I'm not a newbie, but I'm not a pro at this either. Anyone ever have this 'problem'?
Bill
46-350 works too well - by billp - 03-12-2013, 04:20 PM
RE: 46-350 works too well - by TA Forbes - 03-13-2013, 12:12 AM
RE: 46-350 works too well - by Raleigh - 03-13-2013, 12:48 AM
RE: 46-350 works too well - by billp - 03-13-2013, 08:05 AM
RE: 46-350 works too well - by BrendaAnnD - 03-13-2013, 08:22 AM
RE: 46-350 works too well - by Raleigh - 03-13-2013, 11:15 AM
RE: 46-350 works too well - by billp - 03-13-2013, 03:52 PM
RE: 46-350 works too well - by billp - 03-15-2013, 05:21 PM
RE: 46-350 works too well - by billp - 03-18-2013, 01:30 PM
RE: 46-350 works too well - by morzh - 03-18-2013, 01:50 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7115 online users. [Complete List]
» 1 Member(s) | 7114 Guest(s)
