39-116 Chassis Restoration
Thanks Ron for the encouragement. I think I talked to you back in 2002 as I was getting ready to look deeply into the 39=116 chasssis. I even considered sending it to you, but thought it would be a good retirement project and now it is becoming just that.
I will probably need more help as I come to the volume control motor. According to my notes it wasn't working but was stuck at a usable volume which allowed me to make other checks. I was surprised at the sensitivity from my notes. I checked it out with a SG on all bands and it was surprisingly good. I purchased this set from a collector in Galesburg, Il, while visiting my mom. I hauled it back to Texas, then to Kansas and now its my next project.
i plan on a complete rewire with original type wiring. Can you lead me to a good source for the similar wire?
Have a great day.
Peace
bob
39-116 Chassis Restoration - by Guest - 06-08-2010, 01:35 PM
Re: 39-116 Chassis Restoration - by Dave - 06-09-2010, 06:38 PM
Re: 39-116 Chassis Restoration - by Ron Ramirez - 06-10-2010, 08:09 AM
Re: 39-116 Chassis Restoration - by Guest - 06-11-2010, 01:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
