1938 Silvertone model 6152 just restored
This is one of only 3 non-Philco radios in my collection. I purchased it back in 1984 or 1985 at a garage sale in Hartford, WI. It was recapped then and played great. Even the magic eye green tuning tube worked, albeit a bit dim. I listened to it a lot in the late 1980's... I remember in June 1987 learning that Fred Astaire died while listening to it, and in October 1988 listened to the 50th anniversary broadcast of The War of The Worlds over WBBM in Chicago. By the early 90's, the green eye burned out completely. It has been sitting in my basement since then, sadly collecting dust. That is, until this past week, when I got the bug to give it a make over after finding an original replacement 6U5 green eye tube online. That's really the only reason I keep this radio is because that green eye is just plain cool when it works! Here's a before restoration picture:
And here are some after pics:
1938 Silvertone model 6152 just restored - by NostalgiaRadioTime - 03-14-2013, 09:19 PM
There are currently 3486 online users. [Complete List]
» 1 Member(s) | 3485 Guest(s)
