Philco 38-116X vs RCA 15K
Breaking the eye tube socket isn't really a concern unless the set has one of those awful Eby eye tube sockets with the solid Bakelite back. Most of the decent ones with a metal cover were made by Amphenol, opening those isn't too hard but you need a sharp flat bladed screwdriver to wedge into the slots on the cover, it's hard to break one unless you use excessive force. Most of the time when I need to open one up it's because the cable is shot and the wires need to be replaced. Some companies, like Sparton, had enough sense to install the 1 meg ohm resistor under the chassis rather then in the socket itself, the reason they burn out is because they used a 1/4 watt resistor where they should have used a 1/2 watt.
Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 04:19 PM
RE: Philco 38-116X vs RCA 15K - by y2kbruce - 03-13-2013, 04:47 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 05:04 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 03-13-2013, 07:37 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-13-2013, 10:55 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-13-2013, 11:36 PM
RE: Philco 38-116X vs RCA 15K - by OldJack1969 - 10-10-2014, 07:04 PM
RE: Philco 38-116X vs RCA 15K - by jontz - 03-14-2013, 07:14 AM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-14-2013, 06:08 PM
RE: Philco 38-116X vs RCA 15K - by jontz - 03-14-2013, 09:28 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 03-14-2013, 09:41 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-14-2013, 09:51 PM
RE: Philco 38-116X vs RCA 15K - by Jayce - 03-14-2013, 10:58 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 03-15-2013, 10:20 AM
RE: Philco 38-116X vs RCA 15K - by TA Forbes - 03-15-2013, 07:24 PM
RE: Philco 38-116X vs RCA 15K - by morzh - 10-10-2014, 09:27 PM
RE: Philco 38-116X vs RCA 15K - by thirtiesradio - 12-12-2014, 04:49 PM
RE: Philco 38-116X vs RCA 15K - by Arran - 12-13-2014, 02:10 AM
RE: Philco 38-116X vs RCA 15K - by Phlogiston - 12-13-2014, 09:07 PM
RE: Philco 38-116X vs RCA 15K - by thirtiesradio - 12-14-2014, 02:26 AM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10795 online users. [Complete List]
» 1 Member(s) | 10794 Guest(s)
