Automatic Tuning Dial Station Call Tabs
Does anyone here know if/where I might be able to locate new or used station call tabs for my 37-116X ? Almost all of mine are missing. Icon_sad I know that Philco sold them as a separate kit once upon a time...... If only I could just call them up and order some now!
Automatic Tuning Dial Station Call Tabs - by philcobenz - 11-12-2007, 04:40 PM
[No subject] - by 49Stude63 - 11-12-2007, 11:31 PM
call station tabs - by Chris Drumma - 11-15-2007, 03:16 PM
Philco 91 Tuning Condenser
There are currently 10391 online users. [Complete List]
» 2 Member(s) | 10389 Guest(s)
