What my 16B looked like when I got it and then....
I've related how I acquired my 16B chassis and speaker and then got the cabinet later.
I was going through some old pictures and found the 2 that show how it was mounted. The pictures attached show it mounted on the back of a wainscoating door----how it looked on the front side and the back side----and then the completed radio with the correct rough cabinet and then after it was refinished. Luckily a radio club member had the cabinet I needed
Lucky to find both.
Art
What my 16B looked like when I got it and then.... - by Art Hoch - 03-16-2013, 07:10 PM
Philco 91 Tuning Condenser
