general question
The dead short is only seen due to the 1st cap of 10uF, not the second of 60uF. The choke limits the current through the complex impedance, part of which is 2kOhms of active one.
But 60uF will not burn the output xfmr, and the only things that potentially could are: bad output tube 247 or the shorted speaker or a short in prime/second windings of the xfmrs itself.
general question - by DKinYORKpa - 03-16-2013, 05:33 PM
RE: general question - by 7estatdef - 03-16-2013, 06:07 PM
RE: general question - by morzh - 03-16-2013, 07:59 PM
RE: general question - by DKinYORKpa - 03-16-2013, 08:32 PM
RE: general question - by Arran - 03-16-2013, 09:31 PM
RE: general question - by morzh - 03-16-2013, 11:33 PM
RE: general question - by DKinYORKpa - 03-17-2013, 07:49 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2687 online users. [Complete List]
» 2 Member(s) | 2685 Guest(s)
