general question
Sometimes output transformers fail for no apparent reason at all, although the one thing that could do it is the output tube drawing too much plate current perhaps. Many 1939-42 Philcos are notorious for having bad output transformers, they almost always develop an open primary. I don't believe that an output filter cap is to blame, I actually have a few Rogers built sets that use output filter caps of about that size, presumably it was because they were designed for 25 cycle operation.
general question - by DKinYORKpa - 03-16-2013, 05:33 PM
RE: general question - by 7estatdef - 03-16-2013, 06:07 PM
RE: general question - by morzh - 03-16-2013, 07:59 PM
RE: general question - by DKinYORKpa - 03-16-2013, 08:32 PM
RE: general question - by Arran - 03-16-2013, 09:31 PM
RE: general question - by morzh - 03-16-2013, 11:33 PM
RE: general question - by DKinYORKpa - 03-17-2013, 07:49 AM
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Philco 91 Restore Code ??
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
So sometime  back I posted some photos of a badly damaged in transport T62, not the tank. I did manage to get a donor c...Paul Philco322 — 05:43 PM
There are currently 2600 online users. [Complete List]
» 4 Member(s) | 2596 Guest(s)
AvatarAvatarAvatarAvatar
