38-116 just up thge road
I'm no expert. The cabinets are new for 1938, slopped face. The 1938 Model uses different audio output tubes. Unsure as to why. I'd say if you like the cabinet design go for it as the 37-116's I have seen are great radio's.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
38-116 just up thge road - by Drew - 11-12-2007, 06:12 PM
[No subject] - by wonderwrench - 11-12-2007, 06:48 PM
[No subject] - by wonderwrench - 11-13-2007, 01:59 AM
Philco 91 Tuning Condenser
There are currently 9473 online users. [Complete List]
» 3 Member(s) | 9470 Guest(s)
