What my 16B looked like when I got it and then....
Whooops, what happened to my attachment in my last post?
Guess it must have been too large. Wondering if the chevron cloth in this ad was original stuff.
RE: What my 16B looked like when I got it and then.... - by Art Hoch - 03-17-2013, 04:01 PM
Philco 91 Tuning Condenser
There are currently 2966 online users. [Complete List]
» 1 Member(s) | 2965 Guest(s)
