How do you pop out the front panel of a Philco 91?
You may be able to use a small hammer to tap a putty knife between the front panel and the front arch to break the bond. Then use hammer and a block of wood to bump the panel out. If the veneer is damaged in the process, it's really not that difficult to replace.
M R Radios   C M Tubes
RE: How do you pop out the front panel of a Philco 91? - by Steve Davis - 03-17-2013, 09:57 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2527 online users. [Complete List]
» 3 Member(s) | 2524 Guest(s)
