My two Marietta finds.
I was a little shocked at the lack of old radios in the stores around Marietta. Also, not a single Victrola or wind-up, which you usually see at least one of per antique shop around here.
My two Marietta finds. - by Jayce - 03-17-2013, 08:37 PM
RE: My two Marietta finds. - by morzh - 03-17-2013, 09:11 PM
RE: My two Marietta finds. - by Jayce - 03-17-2013, 11:36 PM
RE: My two Marietta finds. - by TA Forbes - 03-19-2013, 01:28 PM
RE: My two Marietta finds. - by Arran - 03-19-2013, 09:23 PM
There are currently 2917 online users. [Complete List]
» 1 Member(s) | 2916 Guest(s)
