Philco 76 resistor values
I have obtained a beautiful Philco 76 highboy console radio. The schematics I find do not show the values of the 5 wire wound resistors - there are 2 gray colored resistors with a yellow tip, 1 white resistor,1 yellow resistor and a green resistor. Does anyone know the value of these 5 resistors? Thanks, Phil
Philco 76 resistor values - by philip vanderoef - 03-18-2013, 02:52 PM
RE: Philco 76 resistor values - by Ron Ramirez - 03-18-2013, 04:47 PM
Philco 91 Tuning Condenser
