PHILCO 98 EXPORT Model
Thanks Ron.
That data is great. You are a star. My resolve to have another go at this old Philco is renewed.
I aquired this one from the UK. Philcos are rare here In Ireland as most radios sold here were made here which was the result of a trade protectionist policy of the early free state. Import tarrifs made it more economicle to produce hare than import. as a result Irish Radios are often unique to Ireland.
I will keep the forum updated and no doubt seek advice.
regards to all.
Willie.
PHILCO 98 EXPORT Model - by HOTWIRE - 10-08-2012, 01:50 PM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-08-2012, 10:33 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-13-2012, 09:44 AM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-13-2012, 09:53 AM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-14-2012, 08:55 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-14-2012, 09:17 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-14-2012, 11:01 AM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-14-2012, 09:26 PM
RE: PHILCO 98 EXPORT Model - by Arran - 10-14-2012, 11:02 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-15-2012, 03:18 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-15-2012, 04:23 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-15-2012, 07:18 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-12-2013, 11:27 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 03-15-2013, 02:04 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-15-2013, 11:14 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 03-17-2013, 01:08 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-19-2013, 09:09 AM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:02 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:06 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:13 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 09-09-2014, 06:47 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 08:19 PM
There are currently 7585 online users. [Complete List]
» 3 Member(s) | 7582 Guest(s)
