Chevron grille cloth in Philcos
Ooops! Big file...my bad...sorry. The reason I have had 2 37-84s is that I think that was the model in our house when I was a little kid. This picture in our farmhouse kitchen was taken of my grandmother about 1950 and you can see the radio to her side. It's a very poor view but that's the model I think it is. I remember the dial was like the 84s. Except the numbers on our dial were all gone, replaced by pencil marks to denote the location of the stations. What do you think? Am I correct>? Wish I had a better pic but I don't.
Chevron grille cloth in Philcos - by Art Hoch - 03-19-2013, 12:07 PM
RE: Chevron grille cloth in Philcos - by y2kbruce - 03-19-2013, 04:27 PM
RE: Chevron grille cloth in Philcos - by Art Hoch - 03-19-2013, 05:37 PM
RE: Chevron grille cloth in Philcos - by Art Hoch - 03-19-2013, 05:52 PM
Philco 91 Tuning Condenser
There are currently 4700 online users. [Complete List]
» 2 Member(s) | 4698 Guest(s)
