41-250 Phono Input?
Except for the push button switches as an additional weak link and a schematic muddying agent there is not that much more tough about this model than it is about others. Electrically it is just radio.
And then there is always the Deoxit Icon_smile
Suerte, good luck, удачи - have fun!
41-250 Phono Input? - by 462ron - 03-18-2013, 09:10 PM
RE: 41-250 Phono Input? - by Ron Ramirez - 03-19-2013, 05:25 AM
RE: 41-250 Phono Input? - by 462ron - 03-19-2013, 04:17 PM
RE: 41-250 Phono Input? - by morzh - 03-19-2013, 06:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
