I have a Philco 41 300 Console Radio
I agree with Ron. Tubes should be removed, individually wrapped for shipment. Chassis and speaker should be removed and packed separately from the cabinet. By the time you do that, total packing and shipping costs would probably be at least double (or more) the amount you could expect for the radio. Unless you got the buyer to pay for all that, you'd be in the hole. As suggested on another forum, try to sell it to the buyer of your house.
I have a Philco 41 300 Console Radio - by Linda@Mayaluga.com - 03-21-2013, 01:37 PM
RE: I have a Philco 41 300 Console Radio - by Art Hoch - 03-21-2013, 08:33 PM
Philco 91 Tuning Condenser
