I have a Philco 41 300 Console Radio
Linda, if your home buyer is not interested in the radio you might try contacting the Antique RAdio Club of Illlinois to see if someone there would be interested; see http://www.antique-radios.org/ especially if you are near the Chicago area. You could also list in craigslist in your local area.
I have a Philco 41 300 Console Radio - by Linda@Mayaluga.com - 03-21-2013, 01:37 PM
RE: I have a Philco 41 300 Console Radio - by klondike98 - 03-21-2013, 10:56 PM
Philco 91 Tuning Condenser
