116X Finish
Yesterday I tried to see if I could remove the "shellack" from the cabinet. I have not worked with shellack before so I'm only going off what the owner says it is. I tried acetone and it didn't even phase the finish even leaving a cloth soaked in the stuff on the finish.
My next attempt will be 50/50 mix of acetone and lacquer thinner.
Anyone else have experience trying to strip shellack? If that's what it really is. Or should I just leave it and fill the grain and tone and clear the sucker?
I also might attempt to patch the hole where the toggle switch is, I have some mahogany veneer that looks like it will match pretty well. Plus if I get it patched and there are minor flaws they should be mostly covered by the Philco decal.
[Image: http://i1129.photobucket.com/albums/m501...559868.jpg][Image: http://i1129.photobucket.com/albums/m501...8c1518.jpg]
-Keith
116X Finish - by ipwizard - 03-04-2013, 10:45 PM
RE: 116X Finish - by Arran - 03-05-2013, 03:24 AM
RE: 116X Finish - by ipwizard - 03-05-2013, 03:43 PM
RE: 116X Finish - by Ron Ramirez - 03-05-2013, 05:54 PM
RE: 116X Finish - by Phlogiston - 03-05-2013, 06:21 PM
RE: 116X Finish - by Arran - 03-05-2013, 08:03 PM
RE: 116X Finish - by ipwizard - 03-05-2013, 08:14 PM
RE: 116X Finish - by Phlogiston - 03-05-2013, 10:30 PM
RE: 116X Finish - by Ron Ramirez - 03-06-2013, 08:57 AM
RE: 116X Finish - by Phlogiston - 03-06-2013, 11:33 AM
RE: 116X Finish - by Chuck Schwark - 03-06-2013, 04:10 PM
RE: 116X Finish - by Ron Ramirez - 03-07-2013, 05:26 PM
RE: 116X Finish - by Phlogiston - 03-08-2013, 01:42 AM
RE: 116X Finish - by Phlogiston - 03-08-2013, 01:51 AM
RE: 116X Finish - by ipwizard - 03-14-2013, 03:37 PM
RE: 116X Finish - by ipwizard - 03-14-2013, 03:54 PM
RE: 116X Finish - by Phlogiston - 03-14-2013, 04:28 PM
RE: 116X Finish - by Arran - 03-14-2013, 06:47 PM
RE: 116X Finish - by ipwizard - 03-22-2013, 04:29 PM
RE: 116X Finish - by Ron Ramirez - 03-22-2013, 04:46 PM
RE: 116X Finish - by ipwizard - 03-22-2013, 08:25 PM
RE: 116X Finish - by Ron Ramirez - 03-22-2013, 08:38 PM
RE: 116X Finish - by Phlogiston - 03-22-2013, 09:12 PM
RE: 116X Finish - by Arran - 04-01-2013, 02:30 AM
New member
Philco 630csx power cord
New member
There are currently 2593 online users. [Complete List]
» 4 Member(s) | 2589 Guest(s)
AvatarAvatarAvatarAvatar
