Has anyone seen this coin-op?
Upon closer perusal, I see something missing on this set. There's a bracket on the side, which presumably held a pillow speaker, which is not in evidence. That could sour the deal. Anyone have a source for vintage pillow speakers?
Time flies like an arrow, fruit flies like a banana
Has anyone seen this coin-op? - by billp - 03-22-2013, 02:09 PM
RE: Has anyone seen this coin-op? - by Jayce - 03-22-2013, 02:59 PM
RE: Has anyone seen this coin-op? - by billp - 03-22-2013, 05:12 PM
RE: Has anyone seen this coin-op? - by BrendaAnnD - 03-22-2013, 06:26 PM
RE: Has anyone seen this coin-op? - by billp - 03-22-2013, 06:45 PM
RE: Has anyone seen this coin-op? - by Arran - 03-22-2013, 11:11 PM
RE: Has anyone seen this coin-op? - by billp - 03-23-2013, 04:40 PM
RE: Has anyone seen this coin-op? - by billp - 03-24-2013, 12:19 PM
RE: Has anyone seen this coin-op? - by Jayce - 03-24-2013, 01:15 PM
RE: Has anyone seen this coin-op? - by billp - 03-24-2013, 01:30 PM
There are currently 4531 online users. [Complete List]
» 2 Member(s) | 4529 Guest(s)
