Philco Jr 80 cabinet-water stain?
I think it should be Perfect Brown Ultra Classic for the outer section and Medium Walnut on the inner section.
I'm not familiar with Ultra Dark Walnut? If it's like Extra Dark Walnut, then it's too dark.
Philco Jr 80 cabinet-water stain? - by klondike98 - 03-22-2013, 08:08 PM
RE: Philco Jr 80 cabinet - by Ron Ramirez - 03-22-2013, 08:39 PM
RE: Philco Jr 80 cabinet - by klondike98 - 03-22-2013, 08:43 PM
RE: Philco Jr 80 cabinet - by klondike98 - 03-22-2013, 08:45 PM
RE: Philco Jr 80 cabinet - by Ron Ramirez - 03-22-2013, 09:08 PM
RE: Philco Jr 80 cabinet - by klondike98 - 03-22-2013, 09:12 PM
RE: Philco Jr 80 cabinet - by 37silverstreak - 03-23-2013, 08:45 PM
RE: Philco Jr 80 cabinet - by klondike98 - 03-23-2013, 09:21 PM
RE: Philco Jr 80 cabinet-water stain? - by Arran - 07-14-2013, 09:41 PM
RE: Philco Jr 80 cabinet-water stain? - by morzh - 07-04-2014, 05:09 PM
