zenith 6D525 chassis wiring
Hey guy's
Have a cute little zenith 6d525 toaster radio I am working on.
The thing needs re-wiring bad.
I need a wiring diagram for this one.
I have a lot of trouble reading the zenith schematics.
I need it spelled out clearly in a wiring diagram.
Does anyone know I might get one of these.
Have multiple areas that I need clarification on, and I am afraid the schematics are not going to do it for me.
Any idea's?
murf
zenith 6D525 chassis wiring - by murf - 03-22-2013, 11:07 PM
RE: zenith 6D525 chassis wiring - by morzh - 03-23-2013, 11:59 AM
RE: zenith 6D525 chassis wiring - by murf - 03-23-2013, 11:22 PM
RE: zenith 6D525 chassis wiring - by murf - 03-24-2013, 03:30 PM
RE: zenith 6D525 chassis wiring - by codefox1 - 03-25-2013, 02:31 AM
RE: zenith 6D525 chassis wiring - by murf - 03-25-2013, 06:54 AM
RE: zenith 6D525 chassis wiring - by murf - 03-28-2013, 06:36 PM
