Non AA5 Philco's
Greetings,
I would like to know if there are later model Philco's table models that have the power transformer in them. By later I mean late 40's and 50's.
Andy
Non AA5 Philco's - by Andy - 03-23-2013, 08:33 PM
RE: Non AA5 Philco's - by TA Forbes - 03-24-2013, 12:02 AM
RE: Non AA5 Philco's - by Andy - 03-24-2013, 01:52 AM
RE: Non AA5 Philco's - by Ron Ramirez - 03-24-2013, 07:15 AM
RE: Non AA5 Philco's - by Andy - 03-24-2013, 01:22 PM
Philco 91 Tuning Condenser
There are currently 5689 online users. [Complete List]
» 1 Member(s) | 5688 Guest(s)
