What my 16B looked like when I got it and then....
Here is the type of chevron or "V" cloth used in 1935-37 Philcos, including the 16B tombstone:
[Image: http://i326.photobucket.com/albums/k420/...8f6f47.jpg]
And this is the 1938 style chevron or "V" cloth used in the 38-1, 38-116, and a few others:
[Image: http://i326.photobucket.com/albums/k420/...016898.jpg]
The second type is the type of pattern you have in your 16B, Art. It originally had the first type. But all of this is academic now since neither pattern is being reproduced anymore.
RE: What my 16B looked like when I got it and then.... - by Ron Ramirez - 03-23-2013, 10:03 PM
Philco 91 Tuning Condenser
