What my 16B looked like when I got it and then....
@Ron,
Alas, at this point I"d take either one for the 38-1 I just acquired.
@Lloyd,
I just used the cloth that was with the 16B when I found it on the door. I didn't have any other and didn't know when a certain pattern was used on what models.
RE: What my 16B looked like when I got it and then.... - by Art Hoch - 03-23-2013, 10:27 PM
Philco 91 Tuning Condenser
There are currently 2993 online users. [Complete List]
» 1 Member(s) | 2992 Guest(s)
