Old output meter
Ran across an old output gauge that I thought I would use when adjusting radios. It reads from 0 to 1.2 with various numbers in between. Printed on the gauge is Output R.M.S. I connected it to the small speaker wires (on the cone) on my Philco 40-190. It moved the needle slightly at high volume, but nothing at medium volume. Is it the wrong type of meter for radio volume? The wires have a positive and negative. Switching them made no difference.
Old output meter - by jmac3ky - 03-25-2013, 07:39 PM
RE: Old output meter - by Bill Kinghorn - 03-25-2013, 11:13 PM
RE: Old output meter - by Doug Houston - 03-28-2013, 12:34 AM
There are currently 10577 online users. [Complete List]
» 2 Member(s) | 10575 Guest(s)
