Philco T-9
Nothing much out of the ordinary, in terms of trouble--they need their lytics replaced, just like any transistor radio of the same period.
They're much larger than the 1000 series, and they perform at the same level. Pretty good tone, if I remember correctly.
Bill
Philco T-9 - by Guest - 11-15-2007, 08:07 PM
[No subject] - by batterymaker - 11-16-2007, 09:15 AM
[No subject] - by Don Lind - 11-16-2007, 01:29 PM
There are currently 4118 online users. [Complete List]
» 1 Member(s) | 4117 Guest(s)
