Model Philco 37-10 Year & Light Bulbs
Well your 37-10 is a 1937 model. I assume the 47 you refer to is a dial lamp?! Should be able to find them the same place you found tubes--AES. Other suppliers have them too.
Model Philco 37-10 Year & Light Bulbs - by SoCal-Poor-Boy - 03-26-2013, 10:55 AM
RE: Model Philco 37-10 Year & Light Bulbs - by Art Hoch - 03-26-2013, 01:33 PM
Philco 91 Tuning Condenser
There are currently 6405 online users. [Complete List]
» 1 Member(s) | 6404 Guest(s)
