Model 20 power transformer
Hi All
Just an update on that PT. Got it yesterday and just finished checking voltages. All is as expected. Got a good one so I'm going to have two
model 20's. One will be a FrankenPhilco model 20/70 but thats another story for another day. Thanks every one for the help.
Danny
Model 20 power transformer - by Danny - 10-26-2007, 11:03 AM
[No subject] - by Ron Ramirez - 10-26-2007, 03:10 PM
[No subject] - by Ron Ramirez - 10-26-2007, 03:17 PM
[No subject] - by Danny - 10-27-2007, 12:11 PM
[No subject] - by Ron Ramirez - 10-27-2007, 12:35 PM
[No subject] - by Danny - 10-27-2007, 02:28 PM
[No subject] - by davemc - 10-29-2007, 12:08 PM
[No subject] - by Terry Judkins - 10-29-2007, 07:47 PM
[No subject] - by davemc - 11-02-2007, 07:02 AM
[No subject] - by Danny - 11-10-2007, 01:17 PM
[No subject] - by Danny - 11-16-2007, 07:12 PM
Philco 91 Tuning Condenser
There are currently 6918 online users. [Complete List]
» 2 Member(s) | 6916 Guest(s)
