Philco What Model
Hi, can you take a picture of it so we can see it? May help determine what model it is. Looks like Philco made a model 60 console in 1934-1935, It has legs.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Philco What Model - by Guest - 11-16-2007, 10:50 PM
[No subject] - by wonderwrench - 11-16-2007, 11:09 PM
[No subject] - by Guest - 11-16-2007, 11:25 PM
[No subject] - by Ron Ramirez - 11-16-2007, 11:34 PM
[No subject] - by Guest - 11-16-2007, 11:39 PM
[No subject] - by Guest - 11-17-2007, 12:06 AM
[No subject] - by Ron Ramirez - 11-17-2007, 11:58 AM
[No subject] - by Guest - 11-17-2007, 06:46 PM
[No subject] - by Guest - 11-17-2007, 10:04 PM
[No subject] - by Ron Ramirez - 11-18-2007, 12:24 AM
[No subject] - by Guest - 11-18-2007, 06:47 PM
[No subject] - by Guest - 11-26-2007, 10:01 PM
Philco 91 Tuning Condenser
There are currently 5413 online users. [Complete List]
» 3 Member(s) | 5410 Guest(s)
