How to deal with cardboard cover for filter cap
A ring of cardboard (paper towel tube sliced down) or fishpaper in the clamp
area will do the job to insulate the can from the chassis ground.
Chuck
RE: How to deal with cardboard cover for filter cap - by Chuck Schwark - 03-27-2013, 01:21 PM
Philco 91 Tuning Condenser
