Model 60 Woes continued
You might try pulling the antenna and oscillator coils, and baking them in an oven for 15 minutes or so, at a temperature not exceeding 180 degrees. Worth a try. Moisture can do strange things to coils...might not help, but then again, it might.
While I have mentioned before that I am not exactly enthusiastic about Model 60 sets in general, I really don't know why you would have trouble receiving a strong local on the low end of the band.
Good luck, Ron.
Model 60 Woes continued - by Guest - 10-28-2007, 12:41 AM
[No subject] - by Texasrocker - 11-01-2007, 10:44 PM
[No subject] - by Ron Ramirez - 11-04-2007, 10:46 PM
[No subject] - by Guest - 11-16-2007, 11:20 PM
[No subject] - by Ron Ramirez - 11-16-2007, 11:28 PM
There are currently 8681 online users. [Complete List]
» 4 Member(s) | 8677 Guest(s)
AvatarAvatarAvatarAvatar
