AC/Tone Control Switch for 37-620
Aye. And make the capacitor you settle on a high voltage >1000 volt type and you're done.
RE: AC/Tone Control Switch for 37-620 - by ozzyrock2 - 03-26-2013, 08:52 PM
RE: AC/Tone Control Switch for 37-620 - by codefox1 - 03-28-2013, 04:37 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
