What is it and why?
Agree, if it ain't on the original schematic, probably not needed or worse.
Bear in mind that now obsolete beacons at near IF frequency sometimes caused interference decades ago, but I think they are all gone.
What is it and why? - by raydog - 03-27-2013, 01:33 PM
RE: What is it and why? - by Ron Ramirez - 03-27-2013, 04:00 PM
RE: What is it and why? - by morzh - 03-27-2013, 09:00 PM
RE: What is it and why? - by raydog - 03-28-2013, 08:56 AM
RE: What is it and why? - by codefox1 - 03-28-2013, 12:56 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
