Philco What Model
May need to go back through your list again, they had a 60B listed but this radio looks like the model 29X.
I`m sure I must have missed the model 60.
I thought 30 bucks was a good deal but it will finish up very well and does look all original
Philco What Model - by Guest - 11-16-2007, 10:50 PM
[No subject] - by wonderwrench - 11-16-2007, 11:09 PM
[No subject] - by Guest - 11-16-2007, 11:25 PM
[No subject] - by Ron Ramirez - 11-16-2007, 11:34 PM
[No subject] - by Guest - 11-16-2007, 11:39 PM
[No subject] - by Guest - 11-17-2007, 12:06 AM
[No subject] - by Ron Ramirez - 11-17-2007, 11:58 AM
[No subject] - by Guest - 11-17-2007, 06:46 PM
[No subject] - by Guest - 11-17-2007, 10:04 PM
[No subject] - by Ron Ramirez - 11-18-2007, 12:24 AM
[No subject] - by Guest - 11-18-2007, 06:47 PM
[No subject] - by Guest - 11-26-2007, 10:01 PM
Philco 91 Tuning Condenser
There are currently 4730 online users. [Complete List]
» 2 Member(s) | 4728 Guest(s)
