zenith 6D525 chassis wiring
Thanks for the link.
I have already checked it out and even emailed him.
The pics don't really show the wiring very clearly.
He said when he did his he did not re-wire it. HE just tried not to touch the wires.
I think I am going to have to find a chassis that is unmolested and use it as a reference to put the wiring back to original in mine with the original tubes.
Thanks
zenith 6D525 chassis wiring - by murf - 03-22-2013, 11:07 PM
RE: zenith 6D525 chassis wiring - by morzh - 03-23-2013, 11:59 AM
RE: zenith 6D525 chassis wiring - by murf - 03-23-2013, 11:22 PM
RE: zenith 6D525 chassis wiring - by murf - 03-24-2013, 03:30 PM
RE: zenith 6D525 chassis wiring - by codefox1 - 03-25-2013, 02:31 AM
RE: zenith 6D525 chassis wiring - by murf - 03-25-2013, 06:54 AM
RE: zenith 6D525 chassis wiring - by murf - 03-28-2013, 06:36 PM
There are currently 7825 online users. [Complete List]
» 3 Member(s) | 7822 Guest(s)
