Difficulty level in restoring 38-3xx
Hi Tony
The RCA jack is not original. It must have been added sometime later on.
[No subject] - by Ron Ramirez - 10-30-2007, 07:20 AM
[No subject] - by 49Stude63 - 10-30-2007, 08:37 PM
[No subject] - by TonyJSenior - 10-30-2007, 10:39 PM
[No subject] - by Texasrocker - 10-31-2007, 12:01 AM
[No subject] - by 49Stude63 - 10-31-2007, 10:43 AM
[No subject] - by TonyJSenior - 11-17-2007, 09:01 AM
[No subject] - by Ron Ramirez - 11-17-2007, 12:01 PM
Philco 91 Tuning Condenser
There are currently 8479 online users. [Complete List]
» 2 Member(s) | 8477 Guest(s)
