The 95 Lives !
Turns out I had a bad resistor which was cutting off the output tubes.
now I need to clean the volume control and put it back together.
The 95 Lives ! - by simplex1040 - 03-29-2013, 10:01 PM
RE: The 95 Lives ! - by Ron Ramirez - 03-30-2013, 08:13 AM
RE: The 95 Lives ! - by simplex1040 - 03-30-2013, 09:05 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
