116X cap question
Working on a 116x. Does the 10uf e-cap that's part of part #103 get connected negative to chassis, or is this one in backwards positive to chassis?
[Image: http://i1129.photobucket.com/albums/m501...d3fbbe.jpg]
And are the two 8uf caps #104, and the other side of #103 connected positive to the choke?
-Keith
116X cap question - by ipwizard - 04-01-2013, 01:32 AM
RE: 116X cap question - by BrendaAnnD - 04-01-2013, 02:25 AM
RE: 116X cap question - by Steve Davis - 04-01-2013, 10:00 AM
RE: 116X cap question - by ipwizard - 04-01-2013, 11:59 AM
RE: 116X cap question - by morzh - 04-01-2013, 02:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
