Philco Stereophonic Model L1561 Help??
The idler wheel is not turning. The motor shaft is turning fine, but the wheel is extremely hard and will not turn on the motor shaft.
Can you identify the model?
RE: Philco Stereophonic Model L1561 Help?? - by ls3nd3l - 04-01-2013, 09:44 AM
