Restoration/code changes
It isn't necessary to bring an earlier production run up to specs of a later production run, unless you want to do so. Icon_smile
Restoration/code changes - by TonyJSenior - 11-23-2007, 07:28 PM
[No subject] - by Ron Ramirez - 11-24-2007, 12:17 AM
Philco 91 Tuning Condenser
There are currently 10229 online users. [Complete List]
» 2 Member(s) | 10227 Guest(s)
