Old Russian Radio museum
English site does not work, so....the numbers are the years of mfrg.
http://oldradio.onego.ru/foy_r.htm
These are from 30-s
http://oldradio.onego.ru/30_r.htm
Look! Reminds you of anything?
http://oldradio.onego.ru/SETS/svd1.htm
Icon_smile
Old Russian Radio museum - by morzh - 04-01-2013, 09:25 PM
RE: Old Russian Radio museum - by Chuck Schwark - 04-01-2013, 09:52 PM
RE: Old Russian Radio museum - by Eliot Ness - 04-02-2013, 10:04 AM
RE: Old Russian Radio museum - by TA Forbes - 04-03-2013, 11:43 PM
RE: Old Russian Radio museum - by morzh - 04-04-2013, 11:45 AM
RE: Old Russian Radio museum - by Arran - 04-05-2013, 02:42 AM
RE: Old Russian Radio museum - by radiohenry - 05-17-2013, 08:04 PM
RE: Old Russian Radio museum - by morzh - 05-17-2013, 08:54 PM
RE: Old Russian Radio museum - by radiohenry - 05-18-2013, 11:39 AM
RE: Old Russian Radio museum - by morzh - 05-18-2013, 02:38 PM
RE: Old Russian Radio museum - by radiohenry - 05-18-2013, 03:57 PM
There are currently 10267 online users. [Complete List]
» 1 Member(s) | 10266 Guest(s)
