Help Philco 37-84 doubts
Time to break out the 38G wire (or so) It's about 25turns and make sure you wind it the same direction as the original. Also turn the volume control all the way up and measure the resistance from the ANT post to gnd. If it is open you will need to rewind the primary on the ant coil too.
Help Philco 37-84 doubts - by CarlosRadio - 03-29-2013, 07:30 PM
RE: Help Philco 37-84 doubts - by klondike98 - 03-29-2013, 08:34 PM
RE: Help Philco 37-84 doubts - by CarlosRadio - 04-01-2013, 07:18 PM
RE: Help Philco 37-84 doubts - by morzh - 04-01-2013, 08:38 PM
RE: Help Philco 37-84 doubts - by CarlosRadio - 04-02-2013, 02:16 PM
RE: Help Philco 37-84 doubts - by 7estatdef - 04-03-2013, 08:22 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6924 online users. [Complete List]
» 1 Member(s) | 6923 Guest(s)
