More ?? (help) on the Crosley 148
Bingo....Started a systematic search after taking a break from the radio first listed all resistors from the parts list then found each one and verified the value and location so far nothing wrong started the same for the caps first one on the list should have been a 0006 I had a 006 located on the 57 plate went through the rest no other discrepancy plugged it in and got some of the stronger stations right off hooked a 2ft lead on the ant terminal and away she went... Thanks to all the gave advice I'm continuing on the learning curve.
Eric
More ?? (help) on the Crosley 148 - by Eric - 03-24-2013, 07:11 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-24-2013, 10:20 PM
RE: More ?? (help) on the Crosley 148 - by LedHed - 03-25-2013, 01:03 AM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-25-2013, 09:26 AM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-25-2013, 08:37 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-26-2013, 04:20 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-27-2013, 02:57 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-27-2013, 05:49 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-30-2013, 10:43 AM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-31-2013, 11:12 AM
RE: More ?? (help) on the Crosley 148 - by Eric - 03-31-2013, 07:27 PM
RE: More ?? (help) on the Crosley 148 - by Eric - 04-03-2013, 01:59 PM
There are currently 10372 online users. [Complete List]
» 3 Member(s) | 10369 Guest(s)
