48-1262 recap
Hello all,
I am steadily working on the chassis of my 48-1262. I've replaced the paper and electrolytics and a few resistors. I am also learning a lot along the way since this is my first restoration.
I've also discovered with my Heathkit capacitor tester that all the mica caps are open. Is it likely that ALL of them are bad? I've read where they tend not to open or short, but all of mine test open.
Do I have any other options on testing the micas?
KE5YUM
48-1262 recap - by ke5yum - 04-03-2013, 03:37 PM
RE: 48-1262 recap - by jerryhawthorne - 04-03-2013, 04:13 PM
RE: 48-1262 recap - by 7estatdef - 04-03-2013, 05:05 PM
RE: 48-1262 recap - by ke5yum - 04-04-2013, 08:00 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6824 online users. [Complete List]
» 1 Member(s) | 6823 Guest(s)
