stuck power tone switch 38-8
any good tips to free this rusted stuck tone/ power switch on a 38-8
stuck power tone switch 38-8 - by simplex1040 - 04-03-2013, 09:56 PM
RE: stuck power tone switch 38-8 - by BrendaAnnD - 04-03-2013, 10:56 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
