Philco 41-296 Troubles
Jerry,
Thanks for the reply. I just woke up, so hope I can make sense..
I measured 49 volts on the Osc plate and 15v on the cathode, however that was with the switch in position 1 where the schematic shows it set, not the BC band. I also measured 85v on the plate of the 1st det. (RF amp/mixer). Yes, I did have the audio on with the signal gen. @ 1000 hz. I plan to re install the gimmic today and look again. I've got some cap legs lifted for testing I need to re-solder this morning before I turn it back on. I will recheck the voltages in the BC band position and a few other things and post back here. Thanks Again!
Brian
Philco 41-296 Troubles - by w5ami - 04-03-2013, 05:13 PM
RE: Philco 41-296 Troubles - by jerryhawthorne - 04-03-2013, 10:03 PM
RE: Philco 41-296 Troubles - by w5ami - 04-04-2013, 07:46 AM
RE: Philco 41-296 Troubles - by 7estatdef - 04-04-2013, 02:05 PM
RE: Philco 41-296 Troubles - by w5ami - 04-05-2013, 05:15 AM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8289 online users. [Complete List]
» 1 Member(s) | 8288 Guest(s)
