Philco 118 code 121 new project+question
Well, I said I was going to give up after finally finishing the 38-116 but my neighbor brought over a 118. Chassis doesn't look too bad, cabinet looks good, speaker should work with a cone! Sure is cramped underneath and with enough cap blocks to keep me busy. Open 1st IF primary, all other coils and iron look good on preliminary inspection. Posting for parts requirements on the classified. Though you would like to see a preview of the chassis bottom.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...e001-9.jpg]
Philco 118 code 121 new project+question - by jerryhawthorne - 04-04-2013, 04:53 PM
Philco 91 Tuning Condenser
