Speaker Glue
Hi all
Does anyone know what is the best glue to glue the speaker cone (at the rim) to the metal rim. The cone is loose all the way around the speaker and I am trying to glue it back. The speaker is working and the voice coil is not rubbing just want to try to glue it back, wondering what a good glue to use Icon_smile.
thanks
Joe
Speaker Glue - by w4rtc - 04-04-2013, 10:21 PM
RE: Speaker Glue - by Arran - 04-04-2013, 10:27 PM
RE: Speaker Glue - by klondike98 - 04-04-2013, 10:31 PM
RE: Speaker Glue - by NostalgiaRadioTime - 04-04-2013, 10:44 PM
RE: Speaker Glue - by Bob Andersen - 04-04-2013, 11:17 PM
RE: Speaker Glue - by Arran - 04-04-2013, 11:47 PM
RE: Speaker Glue - by klondike98 - 04-05-2013, 09:33 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 09:35 AM
RE: Speaker Glue - by Eric Adams - 04-05-2013, 10:41 AM
RE: Speaker Glue - by w4rtc - 04-05-2013, 11:00 AM
RE: Speaker Glue - by Mondial - 04-05-2013, 11:06 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 01:50 PM
Philco 91 Tuning Condenser
