Speaker Glue
I used to use general purpose contact cement, some use G.C service cement which is fine for gluing a cone to a basket but not for fixing tears.
Whatever you do don't use silicone for anything related to a speaker.
Speaker Glue - by w4rtc - 04-04-2013, 10:21 PM
RE: Speaker Glue - by Arran - 04-04-2013, 10:27 PM
RE: Speaker Glue - by klondike98 - 04-04-2013, 10:31 PM
RE: Speaker Glue - by NostalgiaRadioTime - 04-04-2013, 10:44 PM
RE: Speaker Glue - by Bob Andersen - 04-04-2013, 11:17 PM
RE: Speaker Glue - by Arran - 04-04-2013, 11:47 PM
RE: Speaker Glue - by klondike98 - 04-05-2013, 09:33 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 09:35 AM
RE: Speaker Glue - by Eric Adams - 04-05-2013, 10:41 AM
RE: Speaker Glue - by w4rtc - 04-05-2013, 11:00 AM
RE: Speaker Glue - by Mondial - 04-05-2013, 11:06 AM
RE: Speaker Glue - by Chuck Schwark - 04-05-2013, 01:50 PM
Philco 91 Tuning Condenser
